If I understood correctly, the power supply has 36 volts and by means of a linear regulator it stabilizes at 5 volts output.
Ufffff Small amount of energy converted into heat.
Upload photo of the circuit to see it.
Now I don't have the circuit in front, tomorrow I take the picture,
yes, the 36 volts are not stable, they vary between about 22 - 36 v dc, and with a lm7805 type voltage regulator (no inscription) Low to stable 5v to power the processor
.with the 22 - 36v dc, the led strips are also powered
Already solved,
Let me tell you,
With the open structure where it is mounted and having it on, I gave it hot air with a hair dryer at a safe distance, hehe,
After a while I failed and I could see where the fault was, it was a weld detached from the track, in an invaluable cold pole with the microscope, (mine is not very good, rather bad, hehe).
Solve and go,
To avoid future problems I have mounted cooler with a card to adapt the voltage to the 12v that works.
At the moment almost two days running smoothly.
A greeting and thanks to all
