Electronics and Circuit Design
captin homemade regulator doesn't work for me
serunaj1978
hace 6 años
hace 6 años
Good morning I have a captin and looking at google there is a home regulator which carries a BT137 this is the link of the temperature regulator https://www.pinterest.es/pin/239676011404189851/ the problem is that only reduces voltage from 220v to 190 volt nothing else would be the problem? it may be that instead of putting the ceramic capacitor 104 I put a capacitor 104 lentil. Thank you
Salvador perez maximo
hace 6 años
hello very good afternoon llo if you were to compare this receive greetings oki friend.
hace 6 años
hace 6 años
https://electronicagimeno.com/2020200-soldador-jbc-regulable-sl2020
serunaj1978
hace 6 años
Thank you for your comment, but I want to make it home just to not spend also come to see and considering that I live in Argentina and the price of that welder is 110 euros in my country that would be something like 6000 pesos a total madness. same thanks but I would like to solve my problem
hace 6 años
you're welcome, there are up to 15 euros here, lla is crazy but look in stores in your country for an offer is what I can think sorry for you greetings from Spain
JOSE MIGUEL SIRGO PASCUAL
hace 6 años
hace 6 años
Change the potentiometer to one of 200k ohm and you may have less minimum output power. What you say about the capacitor does not cause any functional difference in the circuit. That type of regulator works by phase partition and what it does is to control a timing by means of a RC time constant to produce the priming of the thyristor so that the longer it takes to produce the priming in the thyristor gate, the less energy it will receive The welder, therefore, by increasing the value of the potentiometer we get more delay in the dispro of the triac. When the voltage in the condenser reaches the trigger threshold of the diac (plus or minus 30 volts) the current causes the gate to prime by discharging the capacitor. And a new capacitor charge cycle is initiated by the potentiometer and the limiting resistor in series with the capacitor.
