Electronics and Circuit Design
Differential cables
Volper
Volper
2
hace 6 años
hace 6 años
Tf Hi. I have 4 wires. Brown, yellow green, black and blue. The switches on the left are to give light to three phases of lights each and to the right I only have the differential and the automatic. Where does each cable go? It is assumed that yellow is not a tomatierra, it is a normal light cable. Thank you
celentauro
celentauro
3.878
hace 6 años
The yellow with a green thread is Earth. The challenge should be seen which of them is the live pole, maybe the outputs from the counter help.
Salvador perez maximo
hace 6 años
that mess has a friend so I see how I help you a moment please
Volper
Volper
2
hace 6 años
The three switches are a separate cable that go to the lights. It depends on which garments one or the other works. The thing is if you have to connect for example the blue to the blue in the differential and the other three at 3 on the left. The plug on the left works only with the general and the automatic up. The black and blue cable comes from the differential to the plug, and a black one enters the first switch. Will the two blue ones and the other 3 be placed on the switches? Thank you
hace 6 años
hace 6 años
Hello, good afternoon, the yellow is wrong, the earth is best regards oki amigo.https: //bricolaje.facilisimo.com/instala-un-cuadro-electrico_183443.html
hace 6 años
hace 6 años
Hi. It should be seen which of the cables or colors (regardless of their color since they may not have respected standards) is neutral. This would go to the output of the bipolar thermal, in its neutral. The other three would go in the lower connection of each unipolar thermal, one in each thermal. Regards
Volper
Volper
2
hace 6 años
Hi. Thank you. Already solved. Yesterday blue probe to the differential and the other 3 to the switches and voila.
hace 6 años
A pleasure that you have solved it. Regards
