Old Electronics
Transistor mlc8550 or equivalent.
carloselvira
Hi everyone? Anyone know, please where to find this transistor or its datasheet, or an equivalent? I don't find information anywhere. Thanks in advance.
ELECTRONICA CIENTIFICO
wave on the dvd video cards chínos ... to take vast tin on the legs and pull it.
regards.
neg2013
neg2013
14.048
Good night, the SS8550 must be the transistor to which it refers ... Factory Chinese have a certain distribution of legs, commercial is something else
pr122
pr122
10.397
Generally these transistors are used in signal as switches or regulators, for what I saw is a PNP 40v 1,5A transistor you can use any with those characteristics or higher, greetings
carloselvira
Thank you very much to all for the contributions, I have finally found a store where to find the transistor in question, I have consulted it with the technicians of the store and everything is correct what you contribute, but the solution of pr122, is the most viable and more detailed In case of not finding the transistor.
Very thankful
