Hi, I have a Fisher RS 1058 shunt amplifier and analogue vumeters do not work. I would like to know which one he fails
From already thank you very much.
Comment if the tuning level function works, since one of the 2 is double-function "tuning meter" if it does not work either, check if the instruments are well, internal coils although it is quite rare, greetings
That is what I think I understand that they are cleaned or lubricated I do not know whether to disassemble them. Because the two are nailed and do not move the center of Chanel FM just moves but does not adjust.
do not disassemble or lubricate, from personal experience this is not advisable, almost always end up ruining, if the instruments become bad, it is better to do some watchmaker than before and worked with watches, greetings
