It is better to have the coil manufacturer circuit, because the problem is going to be like connecting the coils, since each manufacturer has a different code. Look at the IF coils, if there is any brand of the manufacturer. The manufacturer used to deliver along with the coils, a circuit with all the necessary components for the assembly, and the connections of the coils and the audio output. The working voltage must also be taken into account, if it is for 110 V or 220 V. It follows from the cabinet that the radio is medium wave and short wave.
