Old Electronics
Combined CBS COLUMBIA record player does not spin
Funes
Funes
2
Hello everyone, I have this combined and the plate does not turn, the speed engine is going well but the "rubber disk" that would have to move the plate does not touch the engine, please, if someone can give me some advice to fix it I would greatly appreciate it, here the photos: [url=/ver-adjunto/aHR0cHM6Ly9jZG4ueW9yZXBhcm8uY29tL3VwbG9hZHMvZGVmYXVsdC8wMDAyLzAzL2ltYWdlLTkxMDI3LmpwZWp=] / imgta / img25 / img25
nicomena2015
nicomena2015
9.501
hello: check well xq, a spring must have been released, keep that transmission pressed against the motor shaft and the plate ... greetings!
pr122
pr122
10.397
hello, in many turntables the plate is the one that pushes the pulley against the motor, if you took it out, the pulley is free and does not touch the motor, they also usually have a function that with a rigid steel wire pulls the pulley when it is in position off, this brings it so that being off and someone rotates the plate manually does not deform the pulley by rubbing the plate at a single point of the same greetings
pr122
pr122
10.397
the automatic could be hard due to lack of lubrication, or the pulley rubber is worn or hardened, this does not have abrasiveness and skidding, check the rubber, it must be soft, and the edge of the plate where it touches to drive totally clean without grease or dirt, do the test in manual function, without activating the automatic, to rule out that it is the latter that causes the problem,
