uhm, you must have problems because even if you remove the valve the instrument moves to the green area ...
It has a plastic adjustment screw, check if it is zero.
If it is not zero, you should buy a microammeter similar to the one it has.
There is a way to adjust it, but you must have experience in mobile coil instruments, so as not to damage it. If you manage to set it to zero, you should verify the calibration at full scale.
