Perhaps for that reason the two cables that I mentioned below are left over, in addition to the fact that the ECL82 is for 6v, and the pin out is the same. The UCL82 is for 50v. It also happens that, connected to the lamp in series and functioning as an amplifier of an ipod, the lamp lights up 1/4 of its intensity, is this normal? Or should I search for a short or dry capacitor or something similar? Thank you for the prompt response and for the help. Warm greetings. Volt Fierce.
Of course, it measures with a tester in AC the voltage that reaches the filament, it is rare that they would have replaced that valve with a UCL82 since the original, if it were as we suppose, is easier to obtain and more economical, since it was used a lot in the Winco record players, and in audio output of some valve TVs, I must have a lot of those new ones, you could measure the cables that you have loose, and if they bring 6v there would be no doubt about the reform, greetings
I tell you to search without success this circuit, it could be a project made at home or built by a student of a school as practical armed lessons, since I could not find something with that brand, in a teaching institute by mail in the 70 something similar was armed but it also had AM, and other bands of OC, greetings
Well yes, the loose wires below are filament (give 6vca). In addition, the resistance that is in series with the UCL82 only leaves the filament 35v and not 50v as it should. (It measures 35VAC the filament and 85VAC fall through the resistance.) Maybe that's why it is under the volume of audio amplification. It could be intentional to extend the life of the UCL82. I will test (doing the calculation) another R that allows more voltage (45v-48v) to the filament Do not worry about the dear colleague circuit. Your opinions have helped me too much. Many thanks and fraternal greetings!
Volt fierce.
Hi dear pr122 how are we? Taking up a previous comment from you about ECL82 valves, I would like to see how possible it would be for you to do me the favor of selling a couple of them and thus leave the radio circuit as close to the original as possible.
Thank you very much for everything and happy end.
Just to greet and comment that I am very happy because I already operated the FM ELA radio which kindly gave me great help here. The solution was in the power supply. He had broken wires in the tunnel module and B + did not reach him. I opened the tunnel (it was not easy to close it) I took out a line and connected to the .B + and the matter was fixed. Now I can enjoy music with very good sound quality. I am very grateful.
Thank you so much that without the help of this forum it would not have been possible to operate the radio. See you soon and ... let's continue restoring !!
