Old Electronics
Volume control in Sansui AU-3900 sound amplifier
Antonio Carmona
Greetings to all! I received for repair a Sansui AU-3900 amplifier that comes from another workshop without the volume control, if anyone knows the characteristics of this piece in terms of its resistance and other details, I will appreciate the information provided to begin the repair of the equipment. Thank you and awaiting your correct answers. NOTE: Attached photo of the team. Sansui AU-3900.jpg [586.73kb]
neg2013
neg2013
14.048
Good evening, you may solve your problem if you simply download the manual or diagram of the device you are repairing. If I enter the model of the device mentioned, this link is the result I obtained:
neg2013
neg2013
14.048
Just click on the blue letters, solve the captcha, wait for another page to be generated, wait for it to appear at the bottom of the previous image the words GET MANUAL or GET MANUAL, you must click there and start the download, If you use a desktop PC, those are the steps, now that you use one of those smartphones, well that's another issue, which I hardly know anything about.
Antonio Carmona
Good!
Grateful for your prompt response. I commented that I entered the link that mentions but more additional information is necessary to start the repair since the previous workshop could not repair the faults presented by the equipment and to top it off they lost the volume control.
Again my thanks for your valuable help.
neg2013
neg2013
14.048
And without a model it will be difficult to get a similar one, the value is appreciated in the diagram, it is a potentiometer with a double / 250 K derivation Ohms (VR701)
Antonio Carmona
Exactly the same is, now it turns out that this amplifier has the "Loudness" function and the cables of this must be connected to either side of both volume controls and to know this I need additional information that I do not see in the link you mentioned.
pr122
pr122
10.397
https://articulo.mercadolibre.com.ar/MLA-756707677-potenciometro-doble-2x-250k-c-derivacion-cambre-_JM?quantity=1#position=5&type=item&tracking_id=330dcdbe-9a85 -4e15-995b-82099d79e1f6
Antonio Carmona
Grateful for the information. Through it I gained knowledge of how the piece is and the derivation for the control of "Loudness". The next step is to try to get it in Venezuela.
