check if the voltage of 300v is in the main filter, if it is not replace it, if this voltage is present, check the + B output of the source, usually around 120v or 130v if this voltage is low, it could be a problem source or high consumption, change the + B filter capacitors usually 47 or 100mf x 160v, comments, greetings
