Old Electronics
I need transistor replacement ... organ fun machine baldwin
Facundo Marcos
Hello friends, I need to replace some power transistors in an old electronic organ brand fun machine baldwin. The code seen in these transistors is GE 47828, unfortunately in the 3 electronics houses in the city of La Plata they can't tell me what I can replace it with. Thank you!
Rigoberto Mtz.
check if they are npn (positive voltage in collector) or npn and the tip 31 and tip32 serve you reviza the datasheet http://www.dca.fee.unicamp.br/courses/EE531/1s2004/datasheet/TIP31.pdf
pr122
pr122
10.397
hello, be very careful with using another encapsulation such as TIP, keep in mind that the arrangement of legs is different from the original ones, greetings
