For this repair it is not enough only with the multimeter. An amplitude modulated RF generator is required to verify operation from the antenna to the speaker. A frequency meter is also needed to verify the operation of the local oscillator, if an oscilloscope is not available. Logically, the ideal instrument was the dynamic analyzer, widely used at that time, which allowed tracking the transmitter signal from the antenna to the speaker.
well then it starts in the swich that separates the fm from the am and the turntable. one more question do you have sound in fm, if you have it check voltages on the fm am key
Dear Joshe. what you have is a brain of an antiquity that in Mexico we called console. the fault is made by the am fm and phono key, which you add to give you the functions, you must draw a picture of all the connections that are welded, then carefully desoldes their place and carries very small nails on the sides they stop the vaquelita lid close them remove the piece, inside it brings a kind of skates that join between one leg and another carefully disassemble one by one clean them again and test. also check that you have an antenna connected to the back screws
