Old Electronics
portable black and white tv
marlon
marlon
109
Hi friends, I have a black and white TV those that bring radio brand coby model cx-tv1 that turns everything on well but the image looks wavy and a black grating that crosses the screen and slowly rises to the top and passes the tuning single channel I do not have any experience in this type of TV arouses me the suspicion that it is vertical there is a filter near that area a little worn but it attracts me that it is not polarized well some advice boy to leave a picture of the TV someone to help me and replace main capacitors has integrated d7231 and heating a little help porfa black and white tv. jpg [20.65kb] tv 1modificado.j pg [55.17kb] tv2modificado.jpg [48.55kb]
pr122
pr122
10.397
Hello, it is a problem of source, filtering or stabilization measures the output voltage of the source, it should be 12v if it is more, suspect the output transistor, if all good, check filtered and rectified you can leave doubts by feeding it with an external source, battery or batteries, greetings
marlon
marlon
109
The tv works with an external transformer, I mean apart and the 12v comes out of the transformer and they call the TV if you can give me more exact data of which capacitors to check I don't have much experience in this type of TV thanks
pr122
pr122
10.397
if you work with external traffic, the problem is in that place, it has to be a stabilized source, if it is, the filtering of the external source must be wrong
