Old Electronics
Change Neon Transformer
Jonatan Soler
Good afternoon, You see, I have a coca cola neon that has recently melted a part of it: The fact is that it is new, and I imagine it is not for the tube but for the transformer. I have disassembled the transformer and wanted to try my luck to change it, the fact is that my knowledge of electronics is nil. I leave here some photos, since it has two transformers, one for the "Coca and the bottle" part and another for the "Cola" part: https://photos.app.goo.gl/p8ivcKbSOxbkCcXq2 What transformer should I acquire? Would you have to change both or just one?
pr122
pr122
10.397
hello, try to change the output cables for the part that does not work, that is, or tests with the exit that does not walk the tubes that are running or the other way around, with the output that you know is going, the part of tubes that do not light, With this you rule out the possibility that the neon tubes are the ones that have the problem, these tubes work with high voltage, you should go to some installer of these posters to get the traffic, although there are very few, greetings.
urano88
urano88
162
You already mentioned to exchange the one that works to know if the neon tube part is ok. Apart if it is the converter (electronic traffic), you can only change the one that does not work, they are independent circuits.
