Old Electronics
Turner 730 audio outputs
mario256
hace 6 años
hace 6 años
hello I need your help is a 730 turner amplifier which has carbonized the ic ps 403 that is marked with a circle I need to know to replace it looks like a potentiometer
tony1.9diesel
hace 6 años
hace 6 años
With PS403 you mean the silkscreen that this component has on the board, it is a variable resistance; the problem is that I have no scheme of that device to see its value, to see if someone has it, anyway look at which components are associated with that variable resistance for example of such leg there is a capacitor of so many microfarads, of the other one resistance of so many ohms, etc. and maybe with a little luck I can tell you its value, its value should be in the order of approximately 1-150K, another solution would be to put a 150k closed butt and with the device on going up very slowly to Turn down the resistance value and leave it at the value where the device starts working well.
luismac2013
hace 6 años
hace 6 años
hello if you notice that the opposite plate has the same component but it is below, the value is 220E I do not know if I understand I wanted to consulate you if you can guide me with a cable of the plate that is in the middle where the relay you have white yellow and black and the black I have it detached and I don't know where it goes. the colors that I have are gray yellow and blue and blue is the one that I have detached
mario256
hace 6 años
I no longer have it delivered but I have a photo and the blue wire I have connected with a red one would be white / black / red and blue / brown
luismac2013
hace 6 años
It is good but what I need to know to which part of the plate goes the other end of the cable. I'm going to look for the return thanks anyway
