but you have a lot of practice is the advisable thing, many times these engines are step by step, controlled by a Ci and the frequency by a crystal, it could be just that a tip of some motor winding is badly welded, the welding should be retouched, to start, then check if you have a speed change key can have internal dirt in that case use a limo contact or try with WD´-40 greetings and luck
GREETINGS if it can be, if you get it, change it. some engines can be uncovered and served internally, I don't know if it's one of those comments
Hi. Under the plate only the axis appears and below it is covered with a printed circuit board. I will insist a little more on the pitch to see. I didn't want to change anything before making sure. At first I did not know anything about schneider but when I discovered the dish inside, I fell in love. It is a heavy equipment mounted on suspension. I would like as a project to install it on a wooden base, I think it would be fantastic.
