Old Electronics
Combined Ken brown x 700 ss
Mozz
Mozz
2
hace 6 años
hace 6 años
Hi, I have a combined ken brown x700 ss. The problem is that it does not play the entire disc. Always come back before finishing the last track of each album, almost at the end. Could you tell me what it can be? Thank you
pr122
pr122
10.397
hace 6 años
hace 6 años
hello, this problem is solved by moving very little the adjustment screw that is under the base of the arm, this is a control of the place of fall, and you must adjust it, so that the arm falls at the beginning of the first track of the disc, if It has the original tray, this headless screw is pointing to the center of the plate parallel to the base, if you bring a winco tray, you are looking out and have a head, greetings
Mozz
Mozz
2
hace 6 años
Hello, thanks for answering. Now is this screw under the tray (where the whole mechanism is) or is it visible from above?
pr122
pr122
10.397
hace 6 años
It is visible from above, but below the base of the arm
pr122
pr122
10.397
hace 6 años
move very little to one side or the other, and in each movement try the fall, until it is in place
Mozz
Mozz
2
hace 6 años
Thank you so much. You solved it for me!
