Old Electronics
Fi coil 472 kcc
Domenec
hace 6 años
hace 6 años
Hello good morning, I have an old radio brand IBERA A-71, one of the intermediate frequency coils has been broken, (the upper adjustment part). Anyone know where I could find coils of this type? Thank you
pr122
pr122
10.397
hace 6 años
hace 6 años
you could repair it, the adjustment is usually with trimers and they are changeable, if the coil is insurmountable you can place any of another radio even of much smaller size, you can even place it inside the original to save the aesthetics of the radio, you can get some in any repair or restoration house of antiques, greetings
Domenec
hace 6 años
Hi thanks for the answer, do you know where I could find?
Domenec
hace 6 años
I can't find any
neg2013
neg2013
14.048
hace 6 años
hace 6 años
Good evening: I upload the diagram (JPG) in one of those to someone else may be interested .. Greetings
Domenec
hace 6 años
Hello good morning, thanks for the scheme, it is very useful
neg2013
neg2013
14.048
hace 6 años
Hello, good morning, you're welcome, I think that I can only help in that, My regards, and successes in the repair ..
Domenec
hace 6 años
hace 6 años
It is broken inside
pr122
pr122
10.397
hace 6 años
hello but this coil is repairable, you just have to change the inner core of ferrite, but I don't think this is the problem of the radio, the IF would be out of adjustment only, regards
Domenec
hace 6 años
Hello again, I am principiantd in this of reappearing radios, how can it be changed?
It is true that the radio turns on very loud volume but does not tune in any station
pr122
pr122
10.397
hace 6 años
look for the problem in the converter stage, check the wave changeover key, clean it with contact cleaner check the converter valve, and stage capacitors, measure voltages check the oscillating coil, get a similar circuit to guide you, for these cases a signal tracker, I see that electrolytic capacitors changed, greetings
Domenec
hace 6 años
I have the radio scheme
Domenec
hace 6 años
I've been looking at the lamp voltages and I don't find the problem
Domenec
hace 6 años
does anyone have any ideas?
Nico4706
Nico4706
3.081
hace 6 años
If the voltages are fine, it is almost certain that the IF coil is not adjusted to the frequency of 472 KHZ, and then the IF signal does not pass, and therefore the audio signal, which comes along with the IF carrier .
Nico4706
Nico4706
3.081
hace 6 años
The only way to know this is by having an amplitude modulated RF generator
