Old Electronics
Ferrite antenna
modulo2k
hace 6 años
hace 6 años
I would appreciate telling me how I try a ferrite antenna, I am trying to put together a radio, getting an old antenna in my hands, but I would need to know if it works - thanks
pr122
pr122
10.397
hace 6 años
hace 6 años
hello friend there are currently 2 forms of RF stage in super-heroin receivers, the antenna coils can be for tandem with equal sections of the local oscillator and tuned or cut-out section, which the oscillating section of the tandem has fewer plates, the coil antenna is also different in the 2 cases, if you can upload a photo of the rod to better guide you on what circuits you should use, greetings
