Old Electronics
HELP = (how to install auxiliary old radio philips
ElPapu xd
hace 6 años
hace 6 años
Friends, I'm new here and I found an old radio still working and I would like to use it as an auxiliary for my PC. I hope you can help me where to make the connections. I have little idea of electronic mail but I solder the basics I just send them photos of the equipment https://adjuntos.yoreparo.com/imagen_post/0004/79/e2cae4720a2991gddgdgdgpdgpdgpdgpdgpdgpdgpdpp//adjuntos.yoreparo.com/imagen_post/0004/79/844f3878300be10560d1517f8dfcedaebb78c856.jpeg[/img[ManythanksIhopeyoucanhelpmebythewaythespeakertakeitouttoputanotherdonotworryaboutit [img]https://adjuntos.yoreparo.com/imagen_post/0004/80/4a8afa98aee51ff20518028c5355e72e2640f2a8.jpeg" alt="" />
neg2013
neg2013
14.048
hace 6 años
Good afternoon, in some of those if we clarify the radio model, you can find diagrams of it, well in some of those you have luck and there is something on the WEB, so with diagrams you can see where to make the reforms that you request. .. Best of luck
Ángel Morales
hace 6 años
hace 6 años
I'll explain. It is very simple on the basis that every audio signal reaches the preamp stage, or the amplifier stage. The audio signal can be "injected" into the volume control, if it has a good signal level it will sound good. Try to inject the external audio directly where indicated in the diagram. If it is a volume control with switch I see no problem. The connection to the switch is with two adjacent legs. Apart from 3 of the volume control itself. Use the tip of a screwdriver to test the ampli and you will know which is the earth and which the signal input.
ElPapu xd
hace 6 años
It has no model is very old or maybe it was deleted in that diagram I connect the auxiliary where it controls the volume before it reaches the volume right?
ElPapu xd
hace 6 años
I still want to remove the radio I connect it by volume right? It has a potentiometer with 3 legs and apart 2 wires are connected that comes from the current if I'm wrong to put burns ???
ElPapu xd
hace 6 años
I sent you there as the potentiometer just updated the photos
Ángel Morales
hace 6 años
I already saw it. The red wires are those that correspond to the switch. The 3 terminals together are soldered to the printed plate. Interpret the diagram, use a screwdriver tip to locate the terminal that is grounded or the one that corresponds to the audio (the one that corresponds to audio will hum a little). Don't touch the red wires, I don't know how much voltage that radio handles, but just in case.
ElPapu xd
hace 6 años
it drives 6volts that what the transformer supplies for it to work
ElPapu xd
hace 6 años
it is difficult to insert the screwdriver without touching several wires
ElPapu xd
hace 6 años
Can I electrocute myself with 6 volts?
ElPapu xd
hace 6 años
hace 6 años
And what would happen to the radio? Would it disconnect or will the 2 sound at the same time?
Ángel Morales
hace 6 años
The diagram is illustrative, you can put a small key that makes the change between radio and auxiliary.
ElPapu xd
hace 6 años
I will try to connect in those 3 legs I hope it does not burn the current will not move
ElPapu xd
hace 6 años
I already put a screwdriver and nothing sounds in the 3 legs
