Tostiarepa
my tostypes
alipic
alipic
4
Good evening, please let me know why my tostyarepas does not heat enough to sew each of the arepas. The same, they remain raw. Could someone tell me why? although the watch does the normal course without any insterruccion Thank you very much for your help that the Lord continues to bless us.
btvíctor
btvíctor
27.259
Good night alipic. It is possible that the thermostat is faulty or that at least one of the two resistors is damaged. Thanks and regards. ------------------------- Edited on 21-08-2016 for the first time. Approach I: ** .- 13 seconds ago From: alipic thanks for the information, but I have one doubt, when you speak of a damaged resistance is that the same not hot -. ** Observations: Effectively. There are a total of 2 resistors. One in each mold for the faces of the arepas. If you have a tester and measure continuity between the visible ends of the two resistors when disconnecting the thermostat terminals (not before taking photos to avoid not knowing how to reconnect them later) it is feasible to determine if there is any damaged resistance. Usually the thermostat is most likely to have problems getting damaged. There are cases where if any cable was gotten disconnected or broken, it can also lead to something similar to leaving the power circuit open. Thanks and regards.
alipic
alipic
4
with power supply of the same tostyarepa btvitor
alipic
alipic
4
btvctor when you talk about a bad resistance is that it does not heat, because these are both hot
btvíctor
btvíctor
27.259
alipic: --- Do the two heat with external power or with the power of the same tostiarepa?
btvíctor
btvíctor
27.259
alipic:---Si ya revisastes ambos lados internos en el tostiarepa y el cableado está intacto, luce que tendrás que reemplazar el termostato.---No se justifica que las resistencias calienten y las arepas salgan crudas.---El termostato es el que controla la temperatura y es el responsable de que las resistencias reciban la señal eléctrica o no.---Incluso de recibir señal y de no funcionar bien el termostato, las resistencias calentarán poco.---Gracias y Saludos.
