Pequeños Electrodomésticos
ATMA electric kettle loses water from the base
MarchiVM
The electric kettle ATMA began to lose water from the base. How to repair it?
Hi. Can you upload a photo of the base? The screws holding the resistor with their gasket are usually loosened. regards
MarchiVM
I can not find the photo upload option
In your original question you will see a figure with a pencil. this is to edit the answer. When you do it in the edition you will see another figure as a picture. That's where you need to add the photos. regards
I left you an image of how to add the photos
