Hi luis38, it is for another utility to like washing machine, is to move a car alternator and generate electric current. I need you to take tacho control so that the torque is constant and so with this plate regulates the current of the brush motor steadily despite the alternating charge of the alternator. I am building an AC generator assembly for research and learning purposes. A sinusoidal alternating current source regulated in frequency according to the speed of rotation of the driving motor.
Dear, I fully understand the idea you are trying to put into practice. Unfortunately I am not very familiar with the machines of the Indesit / Ariston Line.
I never set out to investigate how the Generating Sets compensate for revolutions by increasing consumption in order to maintain constant frequency.
Some time ago a public colleague the electronic scheme of a control module of a Ballay washing machine, which is simpler than the Indesit / Ariston.
If I find it, I'll send it for investigation. regards
Thank you Luis. This board I think is a microcontroller with speed controller of the PWM motor (Pulse, (Wide) Width, Modulated), and is controlled by the microcontroller BITRON CM04 (20 pin), in the photos appears another one different from mine, ic BITRON CM03, I have searched online but nothing, I can not get your datasheet, neither the cm04, nor the cm03. It is manufactured by ST microelectronic. Thanks and see you soon.
