Hello Luis;
thanks for your help as I see you understand this I wanted to ask you if it is possible,
and dismantle the trainer and it seems to prove and does not work.
the dismount is 8 mf, it is worth it or there is some problem of putting another 10 mf or is combeniente put the same. also I'm not very put and I see that it does not indicate polarization so I guess there is no problem connecting. Thanks friend for everything
Dear, if the capacitor is exhausted or defective, the ideal is to change it.
If the original is 8μF and you have a 10μF, you can try it with this one and if it works, then look for the corresponding capacity, since the tolerance range is usually 5%, one of 10μF, exceeds this value.
Since these capacitors do not have polarity like electrolytics, the position of the cables is indifferent. Greetings.
