Hole rubber bellows
Matil Motoneta
Dear community. I came to consult by the Longvie L4613 washing machine of my mother-in-law who broke the rubber ring / bellows of the door. He wanted to get something out that was stuck and got him through. I consult if there is any special "trick", or a hidden screw that prevents me from disarmed. I saw it and it seems simple. But between waiting for the spare, I thought to consult to do better and faster work. Cautious woman worth it for two! I leave some images. Thank you very much for your warnings, tips and answers. Thanks to this community I have been able to repair many appliances in the house. My best greetings. Page 1 of 1 .jpeg [/img]
lusangor
lusangor
56.366
Hi, it's not difficult at all, just look at it a bit. Here I send you link of different videos how to do it. regards https://www.youtube.com/results?search_query=from+fuelle+windder+onder
Matil Motoneta
Hi Lusangor, thanks for your reply.
I have very little space in the place to work. And I can not find any video where I can see how to disarm the front. Is it possible to do that?
lusangor
lusangor
56.366
disassemble the top, then remove the soap dish or soap dispenser, remove the screws from the control panel and then the front screws
luis38
luis38
95.432
Dear, the great advantage of this work in this line of washing machines is that you can remove the front cover of the cabinet and the whole machine is in sight. Usually the bellows is secured with two wire clamps that hold them in the mouth of the door and the tub. In this case it carries a small tube of discharge in the inferior part that avoids the accumulation of water in the sheets of the same and is the one that is seen in one of the photos. regards
Matil Motoneta
Estimados: Luego de mucho tiempo, mi suegra consiguió comprar el fuelle y allí fui a cambiarlo. No desarmé nada, me las rebusqué en el espacio que tenía. Y me fue bastante bien. Realmente, de todos los arreglos que he encarado, este fue el más fácil. Comentarios para que se aprovechen por otras personas que leen: este modelo de lavarropas sólo tenía una brida (abrazadera de alambre) que sujetaba el fuelle a la cuba. Costó un poco que enganche propiamente dicho, y entre los videos que ví una persona sugiere algo que es un golazo: embadurnar en borde del fuelle con agua con detergente (jabón para los platos), mucho. Y ahí patina y corre ligero, haciendo mucho más fácil la tarea. Lo demás, paciencia y maña (poque me pasó que cuando lograba que encastre en un lugar se me zafaba de otro... y no quería mal tratarlo porque se ve tan frágil la goma del fuelle que ya me veía agujereándola otra vez!). En fin, muchas gracias por sus respuestas y ayuda. Por una cuestión de que respondió primero, y tiene menos puntos, le doy como mejor solución a Lusangor. Igual muchas gracias Luis38, siempre tengo respuestas tuyas en todas mis preguntas. Saludos, y muy felices fiestas!!
luis38
luis38
95.432
Estimado, nos alegra que haya podido realizar exitosamente el trabajo. Como dice el dicho criollo, "Masa vale maña que fuerza". Saludos
Matil Motoneta
¡Efectivamente!
Y una simple aclaración: yo sería estimada, atento mi carácter de mujer :D (mi nombre es Matilde)
lusangor
lusangor
56.366
Nos alegra de que lo hayas conseguido, con paciencia y perceverancia.
luis38
luis38
95.432
Estimada, disculpe usted el equivoco. Saludos
