Ariston avl95 does not work
Gastón Esnaola
Hello! I have a Ariston AVL95 washing machine which when I'm going to run the lights 2 and 4 (from top to bottom) somebody has service manual and error codes ????
favallpa
favallpa
2.523
Reply to the new comment. Washing machine does not drain in the allotted time · Check that the filter is not blocked or blocked · Check the drain hose is free of any blockage or obstruction test light or LED blinks The light or solid lit LED, without flash mined, lack of spin balance at random door's lock · Check Drain Pump Wiring · Check drain pump is not faulty · Check level sensor or change · Check the wiring to the level sensor
Gastón Esnaola
Sorry! It's the first and third light !!!
Gastón Esnaola
I observed that it was depleting, but I continued to try to drain even though the drum had no water. From what I assumed the fault was in the pressure switch, clean all the rubber pipes from the drum to the pump and from the pump to the pressure switch, including the filter. There was not much trash or they were covered. I blew the pressure switch diagram through the hose and set everything back. He did not go back to the fault. Thank you very much! Now another fault has arisen, for which I will open a new question.
