Boiler Baxi ECO, ACS starts and stops, heating goes into default
argengaita
I write from Argentina. My boiler Baxi ECO 240 Fi began, a fortnight ago, to give a defect in heating, forcing it to reset, and entering again in alarm (red led). Checking I could find that the microswich, or microinterrer that drives the hot water, did not work, and was always in a position. I made the change, and the boiler started to run normally. After a little more than a week, another problem began, which is the present, in hot water, turns on, and quickly turns off the burner, turning it back on and off. Every time I wanted to turn it off, it makes a strange noise, previous. After several times there it is on for a few minutes, and then goes out again. And in heating, it ignites the burner, and it goes off entering into error. The boiler has an electronic board, which on the back side says Honeywell, and on the side of the components, says CE0051AU1699, TYPE ECONOT00, CD 56.5389.1. I made a test by removing the inner lid, which makes it tight to the hearth, and although it fails a couple of times it is left with hot water on. It seems that when everything is armed, the noise before it goes out, it is like I did not ionize the electrode well, and try to cut the gas valve until it succeeds. But I'm not entirely sure that this is the reason.
Calemdq
Calemdq
23.097
Which of the red led lights up?
argengaita
Hello MDQ, I thank you for the attempt, I am 67 years old, and I work 40 years in boilers of all types of those 40, half in Europe, I took courses in Germany. And here in this country, work with burners and I was in the design of Flamatic burners, and work with Equa burners. And in Europe with Saunier Duval burners, Yunker, they are the best. You imagine, that all your suggestions I know by heart. In fact the Caldera Baxi I know that the Rock of zmEspaña buy, because itsvickers were very bad, and they failed much. From h
Calemdq
Calemdq
23.097
Well, then it will not be difficult for you to find fault; I know that boiler by heart; but as you can imagine I do not have it before me to review it; Did you check all the connectors? because they often make false contacts that drive you crazy; if we do not find the fault outside the platelet then we see how to continue in it; Let's go for parts, said Jack.
Calemdq
Calemdq
23.097
Hello, I see that you edited the question and now you understand a little better, the sound you hear is the "train of sparks"? if so what is going on is that the ionization flame sensor is not detecting flame, check the lead from the plate to the sensor, the connectors and the porcelain insulator of the electrode that is not broken or grounding, and make good contact with the flame, check that and then comment regards !
