Microsoft Windows
Colores y sonido
looleoma
hace 20 años
hace 20 años
He instalado windows98se en una pentium III 700mhz y hay el problema que solo acepta hasta 16 colores y no hay sonido. Parece que hay que instalar los controladores pero no se cuales y de donde,si me ayudan estare agradecido. Aqui les doy info que espero sea de ayuda: Computer Profile Summary Computer Name: Felipe Profile Date: Tuesday, May 10, 2005 14:27:33 Advisor Version: 5.1n Click here for Belarc's PC Management products, for large and small companies. Operating System System Model Windows 98 SE (build 4.10.2222) PCCHIPS M756LMRT 123456890System Serial Number: 123456890Asset Tag: 0123ABCChassis Serial Number: 123456890 Processor a Main Circuit Board b 700 megahertz Intel Pentium III32 kilobyte primary memory cache256 kilobyte secondary memory cache Board: PCCHIPS M756LMRT 1.0Bus Clock: 100 megahertzBIOS: American Megatrends Inc. 062710 07/15/97 Drives Memory Modules c,d 20.40 Gigabytes Usable Hard Drive Capacity18.29 Gigabytes Hard Drive Free SpaceSAMSUNG CD-ROM SC-152CGeneric floppy disk drive (3.5")Generic IDE hard disk drive (20.40 GB) -- drive 0 48 Megabytes Installed MemorySlot '0' has 64 MBSlot '1' is EmptySlot '2' is EmptySlot '3' is Empty Local Drive Volumes c: (on drive 0) 20.40 GB 18.29 GB free Logins Network Drives No details available Installed Microsoft Hotfixes Printers No details available None detected Click here to see all available security Hotfixes. Marks a HotFix that verifies correctly Marks a HotFix that fails verification (Failing hotfixes need to be reinstalled) An unmarked HotFix lacks the data to allow verification Controllers Display Controlador estándar de disquetes [Controller]Controlador primario IDE (FIFO doble) [Controller]Controlador secundario IDE (FIFO doble) [Controller]Controlador SiS 5513 doble puerto PCI IDE [Controller] Adaptador de gráficos PCI estándar (VGA) [Display adapter]LG Electronics (GoldStar) 53V [Monitor] (13.8"vis, June 2001) Bus Adapters Multimedia Controlador de host abierto SiS 7001 PCI a USBControlador de host abierto SiS 7001 PCI a USB None detected Communications Other Devices Standard 28800 bps ModemAdaptador de Acceso telefónico a redesNetwork IP Address: 127.0.0.1 Teclado estándar de 101/102 teclas o MS Natural KeyboardPuerto de mouse compatible con PS/2Concentrador de raíz USBConcentrador de raíz USB Software Licenses Microsoft - MS Office 97 Professional 53430-297-0211377-63302 Microsoft - Windows 98 SE 50829-335-0557747-32819 (Key: MD97J-QC7R7-TQJGD-3V2WM-W7PVM) saludos looleoma
ruddy_rar
ruddy_rar
6.457
hace 20 años
hace 20 años
Entré en google y buscá las especificaciones de tu mother para encontrar los drivers. O entrá a la página de pcchips.
alvarotota
alvarotota
1.093
hace 20 años
hace 20 años
te esta faltando instalar los controladores de video y sonido como bien te dicen lo tenes que buscar en la pagina de pcchips http://www.pcchipsusa.com/download-mainframe.asp y de ahi bajar los drivers para la mother M756LMRT es una mother para PIII y producto discontinuado sonido SiS 7018 Codec (M755LR/M756LRT/M757LR/M810LR/M812LR) video On-Board AGP Driver Intel 810chip (M770LMRT/M771LMR/M766LMRT) tambien esta el de la red y modem los instalas y tendria que funcionar
looleoma
hace 20 años
hace 20 años
Amigos segui sus indicaciones y ahora ya tengo la pc funcionando sin ningun problema . gracias por todo looleoma
