graciass por tu atencion, aca te paso el contenido del archivo. recordame como verificar si el SQLesta iniciado
2016-03-21 08:43:24.87 Server Microsoft SQL Server 2005 - 9.00.3042.00 (Intel X86)
Feb 9 2007 22:47:07
Copyright (c) 1988-2005 Microsoft Corporation
Express Edition on Windows NT 5.1 (Build 2600: Service Pack 3)
2016-03-21 08:43:24.87 Server Error: 17054, Severity: 16, State: 1.
2016-03-21 08:43:24.87 Server The current event was not reported to the Windows Events log. Operating system error = 1502(El archivo de Registros de sucesos está lleno.). You may need to clear the Windows Events log if it is full.
2016-03-21 08:43:24.87 Server (c) 2005 Microsoft Corporation.
2016-03-21 08:43:24.87 Server All rights reserved.
2016-03-21 08:43:24.87 Server Server process ID is 2356.
2016-03-21 08:43:24.87 Server Authentication mode is MIXED.
2016-03-21 08:43:24.87 Server Logging SQL Server messages in file 'C:\Archivos de programa\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\ERRORLOG'.
2016-03-21 08:43:24.89 Server This instance of SQL Server last reported using a process ID of 3720 at 18/03/2016 14:48:32 (local) 18/03/2016 17:48:32 (UTC). This is an informational message only; no user action is required.
2016-03-21 08:43:24.89 Server Registry startup parameters:
2016-03-21 08:43:24.89 Server -d C:\Archivos de programa\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\master.mdf
2016-03-21 08:43:24.89 Server -e C:\Archivos de programa\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\ERRORLOG
2016-03-21 08:43:24.89 Server -l C:\Archivos de programa\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\mastlog.ldf
2016-03-21 08:43:25.32 Server SQL Server is starting at normal priority base (=7). This is an informational message only. No user action is required.
2016-03-21 08:43:25.32 Server Detected 4 CPUs. This is an informational message; no user action is required.
2016-03-21 08:43:25.84 Server Using dynamic lock allocation. Initial allocation of 2500 Lock blocks and 5000 Lock Owner blocks per node. This is an informational message only. No user action is required.
2016-03-21 08:43:25.93 Server Database mirroring has been enabled on this instance of SQL Server.
2016-03-21 08:43:25.93 spid5s Starting up database 'master'.
2016-03-21 08:43:26.46 spid5s Recovery is writing a checkpoint in database 'master' (1). This is an informational message only. No user action is required.
2016-03-21 08:43:26.59 spid5s SQL Trace ID 1 was started by login "sa".
2016-03-21 08:43:27.07 spid5s Starting up database 'mssqlsystemresource'.
2016-03-21 08:43:27.23 spid5s The resource database build version is 9.00.3042. This is an informational message only. No user action is required.
2016-03-21 08:43:28.79 spid8s Starting up database 'model'.
2016-03-21 08:43:28.86 spid5s Server name is 'FUTURA\AXSQLEXPRESS'. This is an informational message only. No user action is required.
2016-03-21 08:43:28.87 spid5s Starting up database 'msdb'.
2016-03-21 08:43:29.32 spid5s Error: 9003, Severity: 20, State: 9.
2016-03-21 08:43:29.32 spid5s The log scan number (194:24:1) passed to log scan in database 'msdb' is not valid. This error may indicate data corruption or that the log file (.ldf) does not match the data file (.mdf). If this error occurred during replication, re-create the publication. Otherwise, restore from backup if the problem results in a failure during startup.
2016-03-21 08:43:29.32 spid5s Error: 3414, Severity: 21, State: 1.
2016-03-21 08:43:29.32 spid5s An error occurred during recovery, preventing the database 'msdb' (database ID 4) from restarting. Diagnose the recovery errors and fix them, or restore from a known good backup. If errors are not corrected or expected, contact Technical Support.
2016-03-21 08:43:29.53 Server A self-generated certificate was successfully loaded for encryption.
2016-03-21 08:43:29.53 Server Server is listening on [ 'any' <ipv4> 1072].
2016-03-21 08:43:29.53 Server Server is listening on [ 'any' <ipv4> 1433].
2016-03-21 08:43:29.59 spid8s Clearing tempdb database.
2016-03-21 08:43:29.59 Server Server local connection provider is ready to accept connection on [ \\.\pipe\SQLLocal\AXSQLEXPRESS ].
2016-03-21 08:43:29.59 Server Server named pipe provider is ready to accept connection on [ \\.\pipe\MSSQL$AXSQLEXPRESS\sql\query ].
2016-03-21 08:43:29.59 Server Dedicated administrator connection support was not started because it is not available on this edition of SQL Server. This is an informational message only. No user action is required.
2016-03-21 08:43:29.81 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:29.81 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:31.53 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:31.53 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:32.53 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:32.53 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:33.56 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:33.56 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:34.56 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:34.56 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:35.37 spid8s Starting up database 'tempdb'.
2016-03-21 08:43:35.56 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:35.56 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:35.95 spid5s Error: 8355, Severity: 16, State: 1.
2016-03-21 08:43:35.95 spid5s Server-level event notifications can not be delivered. Either Service Broker is disabled in msdb, or msdsb failed to start. Event notifications in other databases could be affected as well. Bring msdb online, or enable Service Broker.
2016-03-21 08:43:35.95 spid11s The Service Broker protocol transport is disabled or not configured.
2016-03-21 08:43:35.95 spid5s Recovery is complete. This is an informational message only. No user action is required.
2016-03-21 08:43:35.95 spid11s The Database Mirroring protocol transport is disabled or not configured.
2016-03-21 08:43:36.56 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:36.56 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:36.67 spid11s Service Broker manager has started.
2016-03-21 08:43:37.56 Logon Error: 17187, Severity: 16, State: 1.
2016-03-21 08:43:37.56 Logon SQL Server is not ready to accept new client connections. Wait a few minutes before trying again. If you have access to the error log, look for the informational message that indicates that SQL Server is ready before trying to connect again. [CLIENT: 172.0.0.109]
2016-03-21 08:43:38.15 Server The SQL Network Interface library could not register the Service Principal Name (SPN) for the SQL Server service. Error: 0x54b, state: 3. Failure to register an SPN may cause integrated authentication to fall back to NTLM instead of Kerberos. This is an informational message. Further action is only required if Kerberos authentication is required by authentication policies.
2016-03-21 08:43:38.15 Server SQL Server is now ready for client connections. This is an informational message; no user action is required.
2016-03-21 08:43:39.43 spid51 Starting up database 'Diccionario_042781_001'.
2016-03-21 08:43:40.23 spid51 Error: 9003, Severity: 20, State: 9.
2016-03-21 08:43:40.23 spid51 The log scan number (584:26:1) passed to log scan in database 'Diccionario_042781_001' is not valid. This error may indicate data corruption or that the log file (.ldf) does not match the data file (.mdf). If this error occurred during replication, re-create the publication. Otherwise, restore from backup if the problem results in a failure during startup.
2016-03-21 08:43:40.23 spid51 Error: 3414, Severity: 21, State: 1.
2016-03-21 08:43:40.23 spid51 An error occurred during recovery, preventing the database 'Diccionario_042781_001' (database ID 5) from restarting. Diagnose the recovery errors and fix them, or restore from a known good backup. If errors are not corrected or expected, contact Technical Support.
2016-03-21 08:43:40.23 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:43:40.23 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:45:37.09 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:45:37.09 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:45:47.12 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:45:47.12 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:45:57.15 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:45:57.15 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:46:07.18 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:46:07.18 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:46:17.20 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:46:17.20 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:46:27.21 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:46:27.21 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:46:37.21 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:46:37.21 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:46:47.21 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:46:47.21 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:46:57.21 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:46:57.21 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:47:07.23 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:47:07.23 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:47:17.25 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:47:17.25 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:47:27.25 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:47:27.25 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:47:37.25 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:47:37.25 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:47:47.25 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:47:47.25 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:47:57.25 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:47:57.25 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:07.26 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:07.26 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:17.28 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:17.28 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:27.28 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:27.28 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:37.28 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:37.28 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:41.76 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:41.76 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:47.28 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:47.28 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:48:57.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:48:57.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:49:07.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:49:07.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:49:17.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:49:17.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:49:27.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:49:27.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:49:37.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:49:37.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:49:47.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:49:47.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:49:57.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:49:57.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:07.31 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:07.31 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:17.32 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:17.32 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:27.34 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:27.34 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:37.37 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:37.37 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:47.40 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:47.40 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:57.42 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:57.42 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:07.43 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:07.43 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:17.45 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:17.45 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:25.85 Server The time stamp counter of CPU on scheduler id 1 is not synchronized with other CPUs.
2016-03-21 08:51:27.48 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:27.48 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:37.50 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:37.50 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:13.93 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:13.93 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:23.94 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:23.94 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:33.96 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:33.96 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:43.97 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:43.97 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:50:53.99 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:50:53.99 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:03.99 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:03.99 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:14.02 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:14.02 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:24.04 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:24.04 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:34.05 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:34.05 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:44.05 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:44.05 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:51:54.07 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:51:54.07 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:04.08 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:04.08 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:08.43 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:08.43 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:14.10 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:14.10 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:24.12 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:24.12 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:34.13 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:34.13 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:44.13 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:44.13 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:52:54.16 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:52:54.16 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:53:04.18 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:53:04.18 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:53:14.19 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:53:14.19 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:53:24.19 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:53:24.19 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:53:34.22 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:53:34.22 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:53:44.24 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:53:44.24 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:53:54.26 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:53:54.26 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:54:04.27 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:54:04.27 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:54:14.29 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:54:14.29 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:54:24.30 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:54:24.30 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:54:34.32 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:54:34.32 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:54:44.33 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:54:44.33 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:54:54.35 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:54:54.35 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:55:04.37 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:55:04.37 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:55:14.38 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:55:14.38 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:55:24.40 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:55:24.40 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:55:34.41 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:55:34.41 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:55:44.41 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:55:44.41 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:55:54.43 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:55:54.43 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:56:04.44 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:56:04.44 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:56:14.46 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:56:14.46 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:56:24.47 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:56:24.47 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:56:34.49 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:56:34.49 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:56:44.51 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:56:44.51 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:56:54.52 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:56:54.52 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:04.54 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:04.54 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:08.65 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:08.65 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:14.55 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:14.55 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:24.55 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:24.55 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:34.57 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:34.57 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:44.58 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:44.58 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:54.58 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:57:54.58 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:57:54.58 spid51 Error: 17054, Severity: 16, State: 1.
2016-03-21 08:57:54.58 spid51 The current event was not reported to the Windows Events log. Operating system error = 1502(El archivo de Registros de sucesos está lleno.). You may need to clear the Windows Events log if it is full.
2016-03-21 08:58:04.60 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:58:04.60 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:58:14.61 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:58:14.61 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:58:24.63 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:58:24.63 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:58:34.65 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:58:34.65 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:58:44.66 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:58:44.66 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:58:54.66 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:58:54.66 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:59:04.66 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:59:04.66 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:59:14.69 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:59:14.69 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:59:24.71 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:59:24.71 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:59:34.71 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:59:34.71 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:59:44.71 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:59:44.71 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 08:59:54.72 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 08:59:54.72 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:00:04.74 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:00:04.74 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:00:14.76 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:00:14.76 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:00:24.77 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:00:24.77 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:00:34.79 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:00:34.79 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:00:44.80 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:00:44.80 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:00:54.82 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:00:54.82 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
2016-03-21 09:01:04.83 Logon Error: 18456, Severity: 14, State: 16.
2016-03-21 09:01:04.83 Logon Login failed for user 'Axoft'. [CLIENT: 172.0.0.109]
