Si te sirve de algo aki esta todo lo que dice el pantallazo azul
a problem has been detected and windows has been shutdown to prevent damage o your computer driver-irql-not-less-or-equal this is the firstime you've seen this stop error screean, start your computer, if this screen appears again, follow hese steps: check to make sure any new hardware or software is properly installed. This a new installation, ask your hardware or software manufacturer for any windows updates you might installed. Problems continue, disable or remove any newly installed hardware or software. Disable bios memory options such as caching or shadowing. You need to use safe made to remove or disable components, restart your computer, press f8 to select advance startup options, and then select safe mode
technical information: stop: 0x000000d1 (0x0000b936, 0x00000002, 0x00000001, 0x872b0af6) tcpip.sys-address 872b0af6 base at 87229000, datestamp 4f756a14
