MICRO INTEL E7500 ES COMPATIBLE CON MOTHER PCCHIPS P17G V1.0
jpdstafe
Hola que tal, paso a comentarles: Poseo la mother PCCHIPS P17G V:1.0 15-V33-011000 LINK OFICIAL: http://www.pcchipsusa.com/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=399&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0 MANUAL: http://download.ecsusa.com/dlfilepcc/menu/P17Gv10.pdf actualmente con dicha Mother poseo un micro INTEL Celeron 420 1600 Mhz. http://ark.intel.com/es/products/29734/Intel-Celeron-Processor-420-512K-Cache-1_60-GHz-800-MHz-FSB y mi intencion es cambiar este micro celeron por un micro INTEL E7500 http://ark.intel.com/products/36503/ en el manual de la Mother dice lo siguiente: This motherboard has a LGA 775 socket for latest Intel® CoreTM2 Duo (E4XXX/E2XXX)/ Celeron® D processors with Hyper-Threading Technology and Front-Side Bus (FSB) speeds up to 1066/800/533 MHz. HyperThreading Technology, designed to take advantage of the multitasking features gives you the power to do more things at once. y tambien: LGA775 Socket Processor Support • Supports the latest Intel® CoreTM2 Duo (E4XXX/E2XXX)/ Celeron® D processors with Hyper-Threading Technology • Supports up to 1066/800/533 MHz Front-Side Bus Chipset There are 945GC Northbridge and Intel I/O Controller Hub 7 (ICH7) in the chipsets in accordance with an innovative and scalable architecture with proven reliability and performance. Note: Hyper-Threading technology enables the operating system into thinking it’s hooked up to two processors, allowing two threads to be run in parallel, both on separate ‘logical’ processors within the same physical processor. La pregunta es el micro E7500 de 45nm y 1066mhz de FSB es compatible con esta mother? no habra problema alguno en usarlo? por que el micro actual que tengo el INTEL Celeron 420 1600 Mhz. es 65nm y es FSB 800mhz si bien el manual dice que soporta Supports up to 1066/800/533 MHz Front-Side Bus lo que me desconcerto es que menciona a micros Intel® CoreTM2 Duo (E4XXX/E2XXX) y nose si lo menciona como ejemplos generales o como que especificamente tengo que poner un INTEL CoreTM2 Dua E4500, o un E4700 por ejemplo. que son micros de 65nm y de FSB de 800, tambien la linea de los E2XXX son de 65nm y 800mhz de FSB. y bueno el que quiero poner el E7500 vuelvo a repetir es de 45nm y 1066mhz de FSB. desde ya muchas gracias por sus respuestas. Saludos.
edgar27561
Hola amigo mira estuve leyendo por ahi y te paso lo siguiente-., El mobo que tu dices tiene dos versiones por lo menos Model: P17G Chipset: Intel® 945GC & ICH7 PCB Versión : V1.0 {------------ BIOS : V1.X.08/05/14 y Model: P17G/1333 Chipset: Intel® 945GC & ICH7 PCB Versión : V1.0A {------------- BIOS : V1.X.08/05/14 el problema aqui es que ninguna de estas dos versiones soportan el E7500. Te paso estos enlaces para que veas la lista de procesadores compatibles varían un poco de una versión a otra a si que cheka bien la version que tu tienes.suerte amigo. http://www.pcchips.com.tw/PCCWebSite/Support/CPU_Support_Model.aspx?detailid=399&MenuID=69&LanID=0 http://www.pcchips.com.tw/PCCWebSite/Support/CPU_Support_Model.aspx?detailid=403&MenuID=69&LanID=0 http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?DetailID=399&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0 http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?DetailID=403&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
