Notebooks (Laptops)
de cuanto es el sistema y cuanta ram se puede expandir
MikyKeyboard
OCUPO SABER DE CUANTO ES EL SISTEMA SI ES DE 64 O 32 Y CUANTA MEMORIA RAM SE LE PUEDE AGREGAR A QUI ESTA EL INFORME DE CPU Z....SE LOS AGRADECERIA MUCHO Very Happy CREO QUE CERRE EL TEMA SOY NOVATO EN EL FORO.... DISCULPAS CPU-Z Binaries CPU-Z version 1.58 Processors Number of processors 1 Number of threads 2 APICs Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 1 Processors Information Processor 1 ID = 0 Number of cores 2 (max 2) Number of threads 2 (max 2) Name AMD Turion 64 X2 Mobile TL-58 Codename Tyler Specification AMD Turion(tm) 64 X2 Mobile Technology TL-58 Package Socket S1 (638) CPUID F.8.1 Extended CPUID F.68 Brand ID 2 Core Stepping Technology 65 nm Core Speed 800.2 MHz Multiplier x FSB 4.0 x 200.0 MHz HT Link speed 800.2 MHz Stock frequency 1900 MHz Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size FID/VID Control yes Max FID 9.5x Max VID 1.150 V K8 Thermal sensor yes K8 Revision ID 6.0 Attached device PCI device at bus 0, device 24, function 0 Attached device PCI device at bus 0, device 24, function 1 Attached device PCI device at bus 0, device 24, function 2 Attached device PCI device at bus 0, device 24, function 3 Chipset Northbridge NVIDIA nForce 560 rev. A2 Southbridge NVIDIA nForce 560 rev. A2 Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Memory Frequency 160.0 MHz (CPU/5) CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Bank Cycle Time (tRC) 21 Command Rate (CR) 2T Memory SPD DIMM # 1 SMBus address 0x50 Memory type DDR2 Module format SO-DIMM Manufacturer (ID) Samsung (CE00000000000000) Size 1024 MBytes Max bandwidth PC2-5300 (333 MHz) Part number M4 70T2953EZ3-CE6 Serial number 860AC247 Manufacturing date Week 42/Year 07 Number of banks 2 Data width 64 bits Correction None Nominal Voltage 1.80 Volts EPP no XMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 3.0-3-3-9-12 @ 200 MHz JEDEC #2 4.0-4-4-12-16 @ 266 MHz JEDEC #3 5.0-5-5-15-20 @ 333 MHz DIMM # 2 SMBus address 0x51 Memory type DDR2 Module format SO-DIMM Manufacturer (ID) Samsung (CE00000000000000) Size 1024 MBytes Max bandwidth PC2-5300 (333 MHz) Part number M4 70T2953EZ3-CE6 Serial number 7333ED93 Manufacturing date Week 42/Year 07 Number of banks 2 Data width 64 bits Correction None Nominal Voltage 1.80 Volts EPP no XMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 3.0-3-3-9-12 @ 200 MHz JEDEC #2 4.0-4-4-12-16 @ 266 MHz JEDEC #3 5.0-5-5-15-20 @ 333 MHz Monitoring Mainboard Model 30CF (0x000000EC - 0x00002350) LPCIO Hardware Monitors Hardware monitor ACPI Temperature 0 49°C (120°F) [0xC96] (THRM) Hardware monitor Battery Voltage 0 11.77 Volts [0x2DF7] (Current Voltage) Capacity 0 88800 mWh [0x15AE0] (Designed Capacity) Capacity 1 39309 mWh [0x998D] (Full Charge Capacity) Capacity 2 5210 mWh [0x145A] (Current Capacity) Level 0 56 pc [0x2C] (Wear Level) Level 1 13 pc [0xD] (Charge Level) PCI Devices Description RAM Memory Controller Location bus 0 (0x00), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0547 Revision ID 0xA2 Description PCI to ISA Bridge Location bus 0 (0x00), device 1 (0x01), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0548 Revision ID 0xA2 Description SMBus Controller Location bus 0 (0x00), device 1 (0x01), function 1 (0x01) Common header Vendor ID 0x10DE Model ID 0x0542 Revision ID 0xA2 Description RAM Memory Controller Location bus 0 (0x00), device 1 (0x01), function 2 (0x02) Common header Vendor ID 0x10DE Model ID 0x0541 Revision ID 0xA2 Description Processor Device Location bus 0 (0x00), device 1 (0x01), function 3 (0x03) Common header Vendor ID 0x10DE Model ID 0x0543 Revision ID 0xA2 Description USB Controller (OHCI) Location bus 0 (0x00), device 2 (0x02), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x055E Revision ID 0xA2 Description USB 2.0 Controller (EHCI) Location bus 0 (0x00), device 2 (0x02), function 1 (0x01) Common header Vendor ID 0x10DE Model ID 0x055F Revision ID 0xA2 Description USB Controller (OHCI) Location bus 0 (0x00), device 4 (0x04), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x055E Revision ID 0xA2 Description USB 2.0 Controller (EHCI) Location bus 0 (0x00), device 4 (0x04), function 1 (0x01) Common header Vendor ID 0x10DE Model ID 0x055F Revision ID 0xA2 Description IDE Controller Location bus 0 (0x00), device 6 (0x06), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0560 Revision ID 0xA1 Description Multimedia device Location bus 0 (0x00), device 7 (0x07), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x055C Revision ID 0xA1 Description PCI to PCI Bridge Location bus 0 (0x00), device 8 (0x08), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0561 Revision ID 0xA2 Description IDE Controller Location bus 0 (0x00), device 9 (0x09), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0550 Revision ID 0xA2 Description Ethernet Controller Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x054C Revision ID 0xA2 Description PCI to PCI Bridge Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0563 Revision ID 0xA2 Description PCI to PCI Bridge Location bus 0 (0x00), device 13 (0x0D), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0563 Revision ID 0xA2 Description VGA Controller Location bus 0 (0x00), device 18 (0x12), function 0 (0x00) Common header Vendor ID 0x10DE Model ID 0x0531 Revision ID 0xA2 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 0 (0x00) Common header Vendor ID 0x1022 Model ID 0x1100 Revision ID 0x00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 1 (0x01) Common header Vendor ID 0x1022 Model ID 0x1101 Revision ID 0x00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 2 (0x02) Common header Vendor ID 0x1022 Model ID 0x1102 Revision ID 0x00 Description Host Bridge Location bus 0 (0x00), device 24 (0x18), function 3 (0x03) Common header Vendor ID 0x1022 Model ID 0x1103 Revision ID 0x00 Description OHCI FireWire Controller Location bus 2 (0x02), device 5 (0x05), function 0 (0x00) Common header Vendor ID 0x1180 Model ID 0x0832 Revision ID 0x05 Description System Device Location bus 2 (0x02), device 5 (0x05), function 1 (0x01) Common header Vendor ID 0x1180 Model ID 0x0822 Revision ID 0x22 Description System Device Location bus 2 (0x02), device 5 (0x05), function 2 (0x02) Common header Vendor ID 0x1180 Model ID 0x0843 Revision ID 0x12 Description System Device Location bus 2 (0x02), device 5 (0x05), function 3 (0x03) Common header Vendor ID 0x1180 Model ID 0x0592 Revision ID 0x12 Description System Device Location bus 2 (0x02), device 5 (0x05), function 4 (0x04) Common header Vendor ID 0x1180 Model ID 0x0852 Revision ID 0x12 Description Network Controller Location bus 3 (0x03), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x14E4 Model ID 0x4311 Revision ID 0x02 DMI DMI BIOS vendor Hewlett-Packard version F.32 date 03/03/2009 DMI System Information manufacturer Hewlett-Packard product HP Pavilion dv6500 Notebook PC version Rev 1 serial CNF74574H9 UUID {37464E43-3534-3437-4839-001B24D6500C} DMI Baseboard vendor Quanta model 30CF revision 85.26 serial None1 DMI System Enclosure manufacturer Quanta chassis type Notebook chassis serial None DMI Processor manufacturer AMD model AMD Turion(tm) 64 X2 Mobile TL58 clock speed 1900.0 MHz FSB speed 200.0 MHz multiplier 9.5x DMI Extension Slot designation PCI Express Slot 1 type A5 width 64 bits populated no DMI Extension Slot designation PCI Express Slot 2 type A5 width 64 bits populated no DMI OEM Strings string[0] $HP$ string[1] LOC#ABA string[2] ABS 72/73 81 82 83 84 DMI Physical Memory Array location Motherboard usage System Memory correction None max capacity 2048 MBytes max# of devices 2 DMI Memory Device designation DIMM 1 format DIMM type unknown total width 64 bits data width 64 bits size 1024 MBytes DMI Memory Device designation DIMM 2 format DIMM type unknown total width 64 bits data width 64 bits size 1024 MBytes Graphics Number of adapters 1 Graphic APIs API NVIDIA I/O API NVIDIA NVAPI Display Adapters Display adapter 0 Name NVIDIA GeForce 7150M / nForce 630M Revision A1 Memory size 256 MB PCI device bus 0 (0x0), device 18 (0x12), function 0 (0x0) Vendor ID 0x10DE (0x103C) Model ID 0x0531 (0x30CF) Performance Level Default Core clock 100.0 MHz Memory clock 0.0 MHz Performance Level 2D Desktop Core clock 250.0 MHz Memory clock 0.0 MHz Performance Level 3D Applications Core clock 425.0 MHz Memory clock 0.0 MHz Software Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) DirectX Version 9.0c[/youtube][/url]
methos
methos
3.483
Hola! tu sistema soporta 64 bits, tanto tu procesador como tu Motherboard, ahora con lo de la RAM, Según el manual de tu Portátil soporta hasta 4 Gb de memoria RAM PC2-5300, DDRII (667-MHz): http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf Tu sistema operativo es de 32 bits... Salu2! 8)
