Notebooks (Laptops)
LAPTOP HP LIGHTS, SEND VIDEO BUT SEE BLACK SCREEN (OPACA)
Cyber-Star
A greeting for everyone in the community and in advance thanks for the possible solutions. I have a "HP COMPAQ C700" LCD screen, the problem is this: the laptop received two fall and mysteriously the flex is damaged, I left the screen white and since I had another full screen (a screen with housing, flex and inverter, fully armed, just install and already) of the same HP and same model (C700) remove the flex and replace it by the other. If you ask why not replace the full screen instead of changing the flex only as I did; is because the other screen has the defect of a vertical line to a quarter of a screen, for that defect and reason only replace the flex. When I replaced the flex and put it to the other screen it came to life, it worked again but only for a few minutes and the screen went black, what I did was that from the other screen I took the "inverter" thinking that this was the problem and I know I placed this one (the one that had fallen) but it remained the same. What I thought was that the graphics chip was desoldered and I did the typical test when it happens: connect it to an external monitor via VGA or HDMI and voila! The image on the external monitor looked perfect. So discard that the problem was the graphics chip. The next test was to use the screen that had spare, thinking that this other had burned the lamp and using another flex and a new inverter I did the test but nothing. I decided to compare a lamp and an inverter but when I tried the lamp did not work the same as the new inverter, the screen was still black, better without backlighting as the image was visible through this (the screen) but opaque, without lighting. So buy a full screen, with flex, inverter and housing and the same ... The screen never turned on. I went and got an identical laptop in make and model and for my misfortune and surprise everything worked; the inverters, the flexs, the two screens and the lamp that you buy. I have read that it is a problem in the plate, a fuse, this information I have taken from here but it is about laptops with LED screens and not "LCD" I would appreciate help from someone knowledgeable about the subject and in electronics mainly or anyone Can you help me, please? PS: Sorry for how extensive I was but I did it to be clear on everything I did and I did to rule out the problem that it was 1-: "GPU", 2 - "flex", 3 -. 4.- Lamp and for the 5th and last "screen" since these are not those mentioned, the problems to the "black screen", because I have seen in forums that people trying to help repeat the same as a solution even so when you said that the problem is not flex, inverts nor screen etc., because all this you have tried and therefore discarded. I attached the pictures of the plate to those who can help and know something of the scheme of it. Thank you very much. [Img] http://archivos.yoreparo.com/uploads/imagen_post/0001/16/5c92c26aeac09e2b8ee5efb3d2051fc2f61f73dd.jpeg [/img] http://archivos.yoreparo.com/uploads/imagen_post/0001/ [/Img] [img]http://archives.yoreparo.com/uploads/imagen_post/0001/16/f1bf78206080cf99a5d3412bbc5abe62c873cc16.jpeg" alt="" />
vallin401
vallin401
1.863
Well say first before you look but discard the fuses. you have to look at two on the motherboard next to the connector will be marked with the letter F and a number and the other on the back of the screen next to the connector on the monitor board will also be marked with the letter F and a number. test them with a tester in the option of continuity, is the one that touches the two tips emits a hum and has the symbol similar to that of the wifi signal. when touching with the tips each side of the fuse this will emit a buzzing if it is ok if it is quietly silent. in case of being wrong you will have to replace it or make a bridge but you would leave the fuse unusable and of course it has its risks because it has a purpose. With all my greetings, I hope to be of assistance.
Cyber-Star
Perfect, but it is as I said before ... I explain again: I have the three screens, with flex and invertes and casing, already tested in another C700 all three work perfectly; light, emit the image correctly without problem and also with that other laptop when testing the screens I also tried the lamp that I bought, so I discard that it is problem of the screens as the GPU since I am using it through the VGA to a LED display (TV) without any problem ... In addition I have used a whole day, I have seen movies and everything to see if it gives me some image failure and
Cyber-Star
at all ... Everything perfect. Ah, I also read in this forum about a correction they made about fuse that will not measure continuity since it is a capacitor and to do so would be that the plate is short. Attached the link for you to observe: http://yoreparo.com/computers/notebooks/preguntas/623756/pantalla-led-sin-iluminacion
This is the other where it solves the card:
http://yoreparo.com/computers/notebooks/preguntas/1126424/lcd-sin-iluminacion-sony-vaio-sve11125clp
mac22esperando
The other alternative is that you have to update the bios file. The LVDS pins do not set them because you have to measure them with oscilloscope just like the clock and the data (34 and 36) therefore the reading with tester is not sensible.
Cyber-Star
In the case that I do not measure as you indicate I should do? Exactly where are the diodes located? Could you point it to me in the pictures I attached? If it can be seen? Another thing: why update Bios? Why exactly? How do you relate to the problem?
wilner flores
the friend mac22 waiting gave the problem .. is the same case .. that happened to me .. I made a bridge to the diode and ready .. I left the image .. I share the same solution as the friend mac22 waiting .. poses ...
Cyber-Star
But exactly which? On what scale do I measure it exactly? Do you happen with the same model or another model of laptop?
oscar gallegos sixteen
YOUR PROBLEM IS B + THAT DOES NOT COME TO THE INVERTER, DOES NOT REACH IT SECURELY FOR THE BEATS, SAY YOU DO NOT RECEIVE ANY MORE. YOU MUST BE VERY DUCH OY AND FIND THE FISURES IN THE BOARD. IF YOU KNOW THAT YOU GO BACK TO SEARCH OR IDEA. ALREADY FREQUENCY IN SALT TO LAMP.
