Ticket Counters
Hello ORYX M06E banknote counter, the tickets are sent by air
roque martin cirmi
Hi, I ask. Does anyone know why when the machine counts the bills they get fired in the air and some crowd in the exit mouth? thanks
spova
spova
22
Hi Roque! As you describe the problem is the speed of the motor that rotates the 2 wheels that accommodate the tickets at the exit, the engine may be broken, or you can check if the gear of the motor shaft inside the gearbox of the gearbox is not detached. speed, I hope it helps you, regards
