Lights and Effects
Change smoke machine pump.
andyandres
Greetings, I have a smoke machine, which has a power of 700w, and the smoke throws it at a distance of 3 to 4 meters maximum, so I wanted to know if putting a more powerful pump could get the smoke to fire longer and in greater quantity ... ??? Is this feasible, is it worth doing or not ... ?? Thanks in advance...
lawliet2710
If you throw it harder, it may not be possible to evaporate the liquid and get out and it could hurt someone.
Mario Vera electronico
If the loading chamber (not the tank) becomes too full, forcing an excessive load, being preheated and generating the gases, these act as if it were an old soda siphon. Consequence: increased chamber pressure, glycerin (which it is the liquid that is generally used) expelled in the form of a hot jet and a safe accident. The charging chamber and heater is calculated for an exact amount and density of glycerin.
andyandres
Thanks for the clarification, I hadn't taken that detail into account ...
