Lights and Effects
Electronic circuit to be manufactured.
Matias Nicolas Romero
Good. I need to manufacture an electronic circuit that fulfills the following function: This will be composed, suppose 5 LED's and what you have to do is, when you press the button, you must turn on the 5th and turn off, then the 4th and off, the 3rd and off, the 2nd and off and finally the first It should stay on. Then when pressing again, (when the 1st is on), you should turn on the 5th which will turn off to turn on the 4th and so on until you reach the second, that it should remain on. therefore they would be 1st and second on. It should cause the feeling that the LEDs are stacking one on top of the other. I hope the idea is understood, I need to know if a circuit can be manufactured and what I should use. Thank you!!
Victor E
Victor E
65.783
if one can be assembled, but the circuit must be with a preprogrammed pic with that function. greetings
pr122
pr122
10.397
it could also be done with a caterpillar sequencer, keeping the last led of the cycle triggered with a transistor, from the same signal you take to keep the fourth led to stay on in the next batch and so on until the first led, it would not be very difficult, but you should experiment a little until you get it, regards
pr122
pr122
10.397
you can use a 555 for the pulse generator and a CD4017 as a track counter, the good thing about using a separate pulse generator is that you can vary the frequency, there are many circuits with these ICs, and they are very economical, this would be the basis , then you have to keep firing the last led with a transistor, greetings
