Lights and Effects
Strobe light
Ignacio Gastiasoro
Good Morning! I want to make a strobe light with an LED lamp, what I thought was a circuit with a relay to generate the desired effect by interrupting the power supply to the LEDs. In other words, the source was always powered and only interrupt the power of the LEDs. I would also like to be able to regulate how often they turn off and on. Could you help me with any ideas to achieve this? Thank you
Hi. What power frequency should this luminaire have? Maybe a relay, because of its switching speed does not allow it. If an oscillator and a power stage. How many LEDs do you want to place? Regards
pr122
pr122
10.397
I think the same looks for a circuit with electronic switching with a 555 and a power output
pr122
pr122
10.397
https://www.yoreparo.com/es/electronica/preguntas/1178625/diagrama-de-flash greetings
