Home Theaters
home theater
Yelme Miguel
hello group a question about something I heard nose if it will work or it was a story I have not done because otherwise I should pay the transformer as he says with a microwave diode or are the 220VAC I put the diode in series with a light bulb (of course it is to test if the microwave diode is running) the voltage would go out halfway now my question this would help me for a home theater of 110VAC or I ask too much haha thanks for your answers
romaci2005
romaci2005
4.485
What I would do with the diode is a half wave rectifier. For resistive loads if you can use, for audio it is not recommended. https://www.areatecnologia.com/electronica/rectificador-de-media-onda.html For your Home theater, I suggest that you use a 110V / 220Vac transformer Best regards
