Home Theaters
transformer failing
noanoa
noanoa
26
Good afternoon, friends of Yoreparo, I have a team which does not turn on and verify connections and apparently everything is fine, the only thing I notice is that the model transformer: EM-3082-AC120-1 is NOT delivering the voltages that are or so I think That is why it is my consultation so that you can help me to know if it is failing or not, or what the problem would be. Voltages delivered: yellow wire: 12.93v / 4.33v blue wires: 14.15V
Ennio Montenegro.
It is not clear between which cables you measured. If you apply 120V to the red ones, you have to have. Between each blue with black 12V - 1,5A Between the yellows 8.5V - 0.2A. The secondary voltage may be higher than indicated, because it is measured with the current mentioned.
noanoa
noanoa
26
friend the red wires at the entrance and there are 120V
The black and blue wires measures: 14.15V
12.93V black and yellow cables and the other 4.33V yellow
So if the transformer is failing or are you recommending me? what other test can i do
Ennio Montenegro.
With the transformer de-energized, measure the ohmic resistance between the black and the 2 yellow wires.
It should not measure resistance. If it measures a low value, it is that they are short-circuited between the secondary ones.
noanoa
noanoa
26
I already measured ohmica with the black wire and the two yellow ones and it doesn't measure anything, so it's good?
Ennio Montenegro.
Yes, what should be by induction.
Between the yellow wires you can measure close to 9V.
You can also put a resistance between black and yellow that measures 12.93V and when measuring voltage on the resistance, you should no longer measure 12V.
Pilaraprendiz
Sorry to intrude me, but I don't understand.
The secindario carries 2 independent threads, one of them, the one that outputs through the blue wires, has the black wire in common, with this as a reference, 12vac must be had in each of the blue wires.
The other winding is the one that comes out on the yellow wires and the voltage between the two yellows must be 8.5 vac.
It is not correct to measure from the blue wires to the yellow wires, or from the yellow wires to the black wire, because as part of independent windings, it will give you a hermetic reading and lacking any validity.
Ennio Montenegro.
Correct Pilar ... !!!
That is why he was told the measures to be taken to rule out the failure he mentions.
Among the failures of a transformer is the contact between a secondary and another.
It is clear that in this case it can be induction, but it must be corroborated.
noanoa
noanoa
26
Good friend
I come back again and measure as you tell me
yellow wires: 9.98v
blue and black: 14v
blue and blue: 0
So friend according to that data if the transformer is in good condition or is the fault somewhere else?
Ennio Montenegro.
Correct, you must look elsewhere.
When there is a transformer with secondary with central branch, between the ends (blue wires) you can measure double 28V or 0V, as is your case. But between each blue and black wire you must measure 14V.
Check the voltage at the output of the rectifiers and voltage regulators if any.
noanoa
noanoa
26
ready friend thanks, tomorrow I upload an image of what the transformer feeds to have if you can help me, in advance Thank you.
Pilaraprendiz
This is what you should have in the transformer. 1571437165205-746194584.jpg [1.55MB] Any measurement between a yellow wire with blue or yellow with black, the value you get is not valid.
