Type Designator: 2SD2389
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 80 W
Maximum Collector-Base Voltage |Vcb|: 160 V
Maximum Collector-Emitter Voltage |Vce|: 150 V
Maximum Emitter-Base Voltage |Veb|: 5 V
Maximum Collector Current |Ic max|: 8 A
Max. Operating Junction Temperature (Tj): 150 °C
Transition Frequency (ft): 80 MHz
Forward Current Transfer Ratio (hFE), MIN: 5000
Type Designator: 2SC5200
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 150 W
Maximum Collector-Base Voltage |Vcb|: 250 V
Maximum Collector-Emitter Voltage |Vce|: 250 V
Maximum Collector Current |Ic max|: 17 A
Forward Current Transfer Ratio (hFE), MIN: 55
Noise Figure, dB: -
Type Designator: 2SB1559
Polarity: PNP
Forward Current Transfer Ratio (hFE), MIN: 10000
Type Designator: 2SA1943
Polarity: PNP
Noise Figure, dB: -
