Solo tengo esta Informacion que son: Part numbering system for Peavey TO-3 power transistors. Example: 70484200 = Transistor/NPN/4 amps/200 volt.
CATEGORY/POLARITY/IC VALUE/BVCEO VALUE. de la PDF: semi-conductor-transistor-cross-reference-list.pdf
