Audio
can i replace the mosfet d478 with the irf640
Dumas
Dumas
15
good companions I have the doubt of a replacement I am building an audio amplifier and I have 3 transistors the same is the d478 I do not get it but I have the irf640 that when comparing the data sheet of the same irf supports more voltage and amperage but I am in doubt if I can use it instead of d478. From already thank you very much.
Victor E
Victor E
65.783
if indeed the AOD478 or D478 is a 100 volts 11amper smd mosfet. the IRF640 is another 200 volt 18 amper package, you could try this one since the first one is not replaced on the web.
Dumas
Dumas
15
Hi Victor E I looked at the data sheet of the d478 and it told me mosfet N chanell of 100 or 150 v 11A. You do not know what your replacement can be. Thank you
Dumas
Dumas
15
You're right mate I was looking bad hahaha thanks for spending your time with my doubt
Victor E
Victor E
65.783
Ok, greetings
