Audio
Sony amplifier model TA-AX22 can only be heard through headphones.
sampras222
This amplifier was working when I played the audio input jak, a click sounded on the speakers and no sound came out of them. On the other hand, the headphone output is heard and amplified. I would appreciate some advice, because I have no idea where to start. Greetings. Thank you.
jomi
jomi
38.143
If it sounds by earphones, the amplifier seems fine. I recommend you check the switches that SPEAKER A and SPEAKER B select If these work well, try other speakers
sampras222
Hi Jomi, they say that in the poor man's house, the joy lasts little and it has been, because when I have placed it in its place, it has not worked again.
I have checked with the multimeter that the SPEAKER A and SPEAKER B switches make contact and in fact yesterday I let it work and today I have assembled everything and it still sounds only by headphones.
sampras222
Jomi, I already fixed it. The amplifier was fine.
It turns out that the speaker with which to do the tests, had been cut and therefore no sound came out.
It occurred to me that the speaker could have broken down, I checked and that was it.
Sometimes one goes crazy over the accumulation of breakdowns.
Thanks for everything.
