Audio
Capactoritor value and resistors in 90W applicator
Caioni Sebastian
hace 6 años
hace 6 años
Hello, would someone be so kind as to tell me what voltage the capacitor that is in series with the speaker on this circuit should be? And what power should the resistors be? Is it powered by a simple 80Vdc source. From already thank you very much. Greetings
pr122
pr122
10.397
hace 6 años
The 2N3904 transistor cannot excite 2 2N3055 transistors in parallel, this circuit is poorly designed apart missing stages, friend do not believe everything you see on the web greetings
jomi
jomi
38.143
hace 6 años
hace 6 años
The R of 0.33 Ohms must be 5W wire, 5% The rest of 1/2 W 5% The 4700 uF / 100V capacitor
Caioni Sebastian
hace 6 años
Good morning jomi. Thanks so much for the help. Regards.-
