Audio
sony equipment. HCD-GTZ5
Jesús Villa
hace 6 años
hace 6 años
hello friends of the forum as they are in this opportunity I am writing to ask for your help I have this mine component SONY HCD-GTZ5 that they allocate the keys of the same one I have to have a key pressed to maintain the option but thus the others do not respond, examples when I select cd and loose the key appears usb or radio is the first computer that I got the truth I'm confused give me a hand that can be the rest in the power all well alone that can not be mastered if I select something is changed just wait your comments if Someone repaired this type of fault ... greetings
jomi
jomi
38.143
hace 6 años
hace 6 años
Sometimes the switches become resistive and cause faults like the one you describe .. Depending on the use of the equipment, it might be desirable to change, at least the most used. Ideal todos.No are very expensive. But it is the work that cost
Jesús Villa
hace 6 años
thank you friend (jomi) I will change the switches but I would like you to check the last comment I made up many blessings .....
felipeacotre
hace 6 años
hace 6 años
Hello friend to solve this fault the first thing you have to change is what you say keys that are actually micro suichs, you have to change all, if it is a series or two series, that is a rule, because if nothing else you change the suspect ones and you return the device because the others failed to loose again to uncover again, well after having changed the microsuichs Czech the voltage of the microcontroller, the clok also check the clok can be checked by measuring the voltage, the reset also me the Czechs and the transmission of data that I imagine you already know as it is checked mainly those that go to the memory EEPROM, and also the voltage that feeds this memory the voltage that reflects both the power of the micro as the memory feed must be reflected fixed in your tester ... well all this that although quisas with the change of all the microsuichs already is solved your failure I told you of these other checks to assure the repair of the fault, because as I say if you return the device have to open it for me is very cumbersome .... Lucky partner. And happy repair
Jesús Villa
hace 6 años
thanks friend (felipeacotre) for your comment for there I have to start what you tell me I just want to tell you something more to turn on the computer I can not with the power key I have to use the remote control to turn it on the computer it only works a key the that says CD the rest nothing and also it does the same in the remote control, according to the client says that recently the computer ignited with the same but already it had that problem with the keys that were allocated but now to the worse that no longer it is possible ignite, only with their good control continue to comment, God bless them.
