Audio
I request the position of klingt 8250 transistors
maikypc
hace 6 años
hace 6 años
lost the order of position of transistors klingt 8250 is a mix. someone could help me they are tip 36 ytip 35 thanks regards
maikypc
hace 6 años
Ok if thanks what happens is that I put them that way and when I turn on the wide burn the transistors takes 2 tip36 and 2 35 and burn one 35 and a 36
Milflo
Milflo
1.386
hace 6 años
hace 6 años
Measure the power voltages of the transistors and identify them, one is positive voltage and one negative. Once done you should install it as follows. Positive Voltage .... TIP35 (NPN) Voltage negative .... TIP36 (PNP)
Milflo
Milflo
1.386
hace 6 años
If only one pair of transistors is being damaged is because you have damaged the channel, you must check all the components of the channel and the transistors must remove them to measure them out of the circuit.
maikypc
hace 6 años
Ok thanks.Ok the anpli is cute. Already localic two recistences are surface, are burned but you do not see the name you do not have the data. Thank you
Milflo
Milflo
1.386
hace 6 años
No friend I do not have, look for a similar diagram.
You can upload an image as visible as possible of the complete card and another with the one of the localized part of the burned resistors.
Also the matrices of the transistors driver.
maikypc
hace 6 años
There leave the image, below you see the enrollment and look in interne and with other colleagues but no one has diagram or data. ?
maikypc
hace 6 años
If I already had a chance to see that diagram. But you noticed that the positive voltage goes to the type 36 manifold and the Nagative at 35. what do you think?????
maikypc
hace 6 años
hace 6 años
U
Milflo
Milflo
1.386
hace 6 años
Enter this page, there is a diagram and check if it is similar to the one you are looking for.
ELECTRO ESP: 100W RMS Guitar Amplifier.
Milflo
Milflo
1.386
hace 6 años
I had not noticed and you're right, but there are diagrams that have errors of all kinds.
The important thing in the diagram is to see if it is similar to the one you are looking for.
If you download the datasheet of the transistors, there you will find with which voltage they must work and if you invest they will be damaged.
NPN .... positive
PNP ..... negative
