Professional Audio
Rca Connector False
demon666lc
Good afternoon!! I have a problem with an RCA card that is connected to the power of the car. The RCA that is about 6x9 is from another brand and I am perfect, it doesn't move or anything. But the RCA DEL WOOFER dances .. it moves a little and when I grab a little I feel that the woofer is heard and then cut. My question is ... how could I do so that the male RCA chips engage well and do not move in the RCA power connector? I can try gluing them with something (not epoxy steel to not damage the components .. or break it when I take it out). Any tape ... or something? What do you recommend? so as not to change the entire cable .. Or is it best to put 2 new rca? or 2 new chips?
Hi. If the chip moves it is best to change it or try to adjust it. There may be a false contact in your welding. Have you checked the board? regards
demon666lc
Yes, the plate is fine, just dance the card .. I will try to open the metal part that has around the tip .., if I cut that connector and splice another cable with rca output ... it works without problems no ?
Yes, as long as you do a good welding and do not touch each other the cables are no problems. Another option is to replace only the tab.
demon666lc
RARE, BUT HAD 4 RCA CONNECTED .. PROBE INVESTING THE RCA AND CONNECTED PREFECT !! AND THOSE WHO WERE FLOJOS, IN THE OTHER CONNECTOR WERE PERFECT ALSO !! NOSE Q WILL HAVE PASSED, BUT IT WAS SOLVED
