Professional Audio
Help with a QSC MX 2000 amplifier
Hec Hernández
Greetings to all of the community, I tell you there is a piece that I don't know if it is a varistor or thermistor which does not have printed nothing go not one of the two and eh searched in other QSC of the same model and come the same do not bring anything printed or serial number, registration number or something for replacement I hope you can support me is on the plate of powwer and reset attach photos and my email to send more photos while I thank you in advance email: zerohg14@gmail.com
romaci2005
romaci2005
4.485
R2 is an NTC thermistor, it belongs to the AC circuit: SG160 Ametherm Thermistor 2.5 Ohms 15% 15A http://www.ibselectronics.com/ibsstore/datasheet/SG160.pdf http://www.ibselectronics.com/ibsstore/sg160-ametherm-thermistor-2-5-ohms-15-15a.html https://elektrotanya.com/qsc_mx2000_sch.pdf/download.html Successes in repair. Best regards
Hec Hernández
Greetings thanks for the support, one more situation I am from Puebla Mexico and I have not been able to find the piece only by request but it comes out very expensive I get in 50 dollars there will be some replacement for the piece ?, I thank you in advance.
JB-CANCER
JB-CANCER
595
Friend as I answered yesterday before I went off line in the other question you raised and I saw that you already solved the problem of uploading the images with the help of the forum link is a PCT or -a NTC you have to identify in the list QSC MX-2000-parte.pdf [78.79kb] What are the 2 pieces to look for?
Hec Hernández
Greetings the detail is that your listing is from MX series A
and the one I say is only MX series
JB-CANCER
JB-CANCER
595
ok the other manual says mx1500 and 2000 without a but it does not allow me to modify the answer to load the other one there is the 2 diagram at the end I think one of the links above is the same as the one I have checked there is to see
