Professional Audio
I NEED HELP with power amplifier high mistral 6000
alexander2112
good colleagues I leave a power amplifier high mistrol 6000 and I leave everything destroyed and I rebuilt it but when I turn it on the temperature rises the transistors MJE15032 and MJE15033 and I don't get how to control the Bias please I need urgent help
alexander2112
Thanks but the diagram I already have it
alexander2112
Excuse me, marqie acectada solution if you want. But change the briver and mount other originals of the same numbering and nothing
Victor E
Victor E
65.783
there I pass the service manual with the circuit, it can be helpful http://schems.com/bmampscom/alto/alto%20mistral%206000%20pwr%20sm_.pdf
Victor E
Victor E
65.783
I change the tr. driver that drives the mje15032 and mje15033 drives - check the bias adjustment preset.
mark_1524
Friend BIAS adjustment, it is not done by having different transistors, maybe you should change all, otherwise you have the manual to see in which position to put each transistor, or new transistors
